We have developed a set of 3 Ducts to reduce under bonnet temperatures. The first is a large Nose mounted Naca Duct combined with 2 inverted Naca
Ducts mounted on the back edge of the Bonnet near the Scuttle. The first lets cool air in, the second two let warm air out. The nose duct has compound
curves in order to fit the contours of most 7 type nosecones.
The set of three in GRP is £85 plus p&p. They come trimmed and ready to fit in either Black,White or Grey Gelcoat finish.
Fitting requires a hole cutting (templates provided) 10mm under the size of the Ducts. The whole does not have to be perfect as the flange on the
Ducts with cover the cut edge. The Ducts are simply then either screwed,riveted or bonded into place.
Thanks for looking Warren. Carbon Copies Ltd
