CLASSIC MINI ADJUSTABLE BRAKE BIAS CABLE or HYDRAULIC CLUTCH TOP MOUNTED PEDAL BOX
(we are aware this is not a Locost product, however you or you may know some one that may need a Classic Mini pedal box solution)
This pedal box has been designed specifically for the Classic Mini we have worked very closely with a Mini specialist to create a hi-performance
system that is easy to fit. We are confident that our Mini bias brake pedal box is by far the best solution available on the market.
This is a total replacement pedal box, not an add on part that does not work. We have tested and designed the 6:1 pedal ratio to give optimum pedal
performance.
All our pedal boxes are manufactured in our UK based factory, this is how we can maintain the highest level of quality control.
The Mini pedal box is a light weight mild steel under-slung pedal box design, that offers the driver the highest level of efficiency in this critical
area. The ergonomic design features a fabricated lightened steel brake and clutch pedal with oil impregnated spherical bushes that sets new standards
in pedal box design. This pedal box is fitted with a bias bar that operates a dual master cylinder braking system, giving total control over the
braking from front to rear.
Please have a look at the solutions at:
www2.obp.uk.net/catalog/index.php?cPath=32_52_143&osCsid=64448d751a55f2018f83837af9f1d4bf
Thank you for your time.
All the best,
Grant
obp Ltd
www.obp.uk.net
