Started....but not anymore....`
JamesyCottony - 15/4/16 at 08:16 AM
Hi there,
Basically, I couldn't get the car started so dad called one of his friends that is building a MG A. With only being there 20 mins the car started!! HORRAY!! But once you let go of the choke it was cutting out, so my dads friend said take the bell housing off the carb. He lightly sanded (WITH 2500 GRIT, SO VERY FINE) the needle and the piston inside, there are no scratch marks WHATSOEVER from this, so I know there isnt a leak from the piston end of the carb. He then blew out with a compressor the jet and the mixing chamber (while still built up, didnt take jet out). After putting back together......IT WOULDNT START!!!!!!!!
So i took the bottom of the carb off and cleaned all of the float ect out, but left the jet in.
Back together....still wont start.
There is fuel there and it is all sparking correctly.
Please help
EDIT: Austin Metro 998cc 1984
[Edited on 15/4/16 by JamesyCottony]
COREdevelopments - 15/4/16 at 08:23 AM
have you tried covering the inlet of the carb while cranking?
Rob
JamesyCottony - 15/4/16 at 08:26 AM
Rob
Air Inlet?
Fuel Inlet?
COREdevelopments - 15/4/16 at 08:28 AM
air inlet. are the plugs wet?
JamesyCottony - 15/4/16 at 08:29 AM
Havent covered air inlet no.
Plugs are dry :/
I just hate cranking it over and over while the pump is trying to chuck fuel in, makes me nervous
nick205 - 15/4/16 at 08:33 AM
As above, get someone else to crank it while blocking (with your hand) the air inlet. That may well let it fire up.
The other way is to get some "easy start" in an aerosol can and spray it in the air inlet while cranking. It's worked for me before to get engines going.
COREdevelopments - 15/4/16 at 08:37 AM
take the dashpot off and check to see if the piston is fitted the correct way, some su's have 2 groves in the piston for location. looking from the top of the piston you should have 2 holes approx 3mm in diameter, these should be facing towards the engine. this is what gives the vacuum. sounds like your pistons are not rising easily.
hth
Rob
JamesyCottony - 15/4/16 at 08:39 AM
hth
Rob
Ill check that, thanks. We did put some 20w50 in the pot to help lubricate it when we took it apart the first time but when it didnt start we drained what was in there out. When cranking I was pushing the little button (to the NS of the engine) that raises the piston, but still nothing, Ill double check the grooves now.
Also would I cover the air inlet because the mixture is too lean?
COREdevelopments - 15/4/16 at 08:41 AM
Do you mean the button on top of the float? That allows more fuel into the float chamber not the piston on the main carb body.
Covering the inlet up will force the piston to lift if it is said problem that I mentioned. Have you palyed about with mixture?
Rob
[Edited on 15/4/16 by COREdevelopments]
COREdevelopments - 15/4/16 at 08:46 AM
The 2 holes in the piston above should be facing the engine.
JamesyCottony - 15/4/16 at 09:07 AM
Put my hand over the inlet.... IT STARTED!!!!!!!!!!!!!!!! THANK YOU GUYS!!
now seems to start without covering inlet.
One thing that I think might be the mixture is when i put some throttle on (after it being warm) it dies quickly then picks up quickly, too much fuel? not enough fuel? too much air? not enough air?
JamesyCottony - 15/4/16 at 09:23 AM
Only one groove, and yea, holes are facing the engne
Andy D - 15/4/16 at 09:25 AM
Have you put the oil back in the dash pot? It's not for lubrication, it's for damping the piston.
JamesyCottony - 15/4/16 at 09:50 AM
There is a little in there still yes
JamesyCottony - 15/4/16 at 10:21 AM
I didnt get a lot of history with the car, so Im not 100% sure that it has been converted to unleaded, the guy before me seems to think so, he recalls something to do with Valve timing was changed. My wallet doesnt mind me spending out on Lead additive, should I just use it anyway? even if the engine is unleaded? just to be on the safe side
MikeRJ - 15/4/16 at 10:46 AM
Covering the inlet won't make the piston lift up. Piston height is a function of airflow and covering the inlet reduces airflow. Choking the inlet simply lowers the pressure in the carb and pulls more fuel up through the needle jet.
It's possible that a jet was partially blocked, chocking the inlet to help pull any crud through is an old trick that often works.
Fill it to the top of the damper tube. The damper is the equivalent of the accelerator pump in a fixed jet carb, if it doesn't have sufficient damping then you get a lean mixture and hesitation when opening the throttle.
BTW you should never use abrasives on the needle, dashpot or piston, especially not wet and dry paper.
[Edited on 15/4/16 by MikeRJ]
JamesyCottony - 15/4/16 at 10:48 AM
What oil would you recommend? im guessing it will have to be mineral as synth will ruin the seals
cliftyhanger - 15/4/16 at 10:49 AM
Just use it. I haven't converted any of the (10 or so) old cars I have owned (except the one I bought with the engine already machined and in bits, seemed silly not to spend £80 on converting it...)
If you suffer valve seat recession, then get unleaded inserts fitted. It is a big if, none of mine ever suffered, and many got driven hard.
ian locostzx9rc2 - 15/4/16 at 10:58 AM
If you have a spark at the plugs and after cranking the plugs are dry then it's a fuel issue has it got fuel in the tank ? Is fuel getting to the carb ? Pour some fuel into the carb ( little bit ) half an aerosol cap if it starts and runs for a few seconds then you know engine must have compression and the timing is ok or close to correct .
JamesyCottony - 15/4/16 at 11:04 AM
I dont have a cat, or o2 sensor and its meant to improve octane, but would it do any damage if I put lead in?
Got it running now thankyou
britishtrident - 15/4/16 at 04:47 PM
Really not a good idea to use any kind of abrasive no matter how fine on the piston or dashpot bore or jet needle in an SU carb.
Cleaning with and sof trag is all that is required. If after cleaning the piston isn't returning freely slacken the 3 screws very slightly and wiggle it a little then tighten them gradually and evenly. If that dosen't work try centering the jet by slackening the jet holder wiggle it and re-tighten.
If that dosen't work try it without the needle fitted if it OK without it the needle is bent, if it still sticks it is highly probable the dashpot has been damged by getting dropped.
JamesyCottony - 15/4/16 at 05:34 PM
It's starting now thankyou, just need to get it running smoothly. When I press the throttle it dies but then picks up quickly, not enough fuel getting in?
rusty nuts - 15/4/16 at 06:39 PM
I was taught to clean SU piston and dash pot with brake fluid 50 years ago, it still works and is cheaper than carb cleaner. Clearances between pistons and dash pots are critical and as BT points out never use any abrasives.
JamesyCottony - 15/4/16 at 08:10 PM
You guys reckon I have ruined the carb then?
It wasn't an all over harsh sand, it was just to get the muck off the surface with 2500 paper
mark chandler - 15/4/16 at 09:54 PM
You will not have done it any favours, but not all may be lost.
Anyway, depending on the carb it may have a lifting pin on the underside which raises the piston slightly when pushed, little rod, Spring and circlip if not use a screwdriver to lift the piston 1/4" when idling.
If the revs increase it is running to rich so back out the mixture screw, to weak and the revs will drop, set correctly and the revs may rise slightly or stay the same.
If it stalls or does not Rev cleanly when you crack open the throttle the oil in the dashpot is to thin so try a heavier grade.
JamesyCottony - 16/4/16 at 12:04 AM
How much do I fill the dashpot? Also surely not much damage was done as it still runs? And when I Rev it (after it dies then picks up) it sounds really nice
cliftyhanger - 16/4/16 at 05:02 AM
Have you topped the damper oil up? (20/50 oil best, thinner oil reduces the enrichment, thicker increases it)
Lead additives don't contain lead (ok, a couple do but hard to find, even if they are still available) most contain a brew of other stuff that hopefully does the same job as lead, but do your research as to which ones work. There was some proper lab tests a few years ago, IIRC the castrol one was OK. And another which I can't remember. Most others did nothing very much.
But as I said, these cars will run for years with no issues as the seats harden up with lead memory from when leaded fuel was about. Our mini has been with us for several years, never used additives. Head off recently, no recession at all and no sign of unleaded seats either.
JamesyCottony - 16/4/16 at 06:03 AM
How much oil goes in the dashpot and where does it go? In the small hole and to the top?
ian locostzx9rc2 - 16/4/16 at 06:31 AM
The oil to the dash pot going in the top unscrew the cap on the top of the carb you only need a tiny bit of oil in it 20/50 is best but 10/40 will work ok .is it idling now if so make sure it hasn't got any air leaks around the carb and inlet manifold spray carb cleaner/ wd40 around the area if the revs change you may have an air leak ,also worth putting the area you live as I'm sure there would be someone locally on here that could take a look .
[Edited on 16/4/16 by ian locostzx9rc2]
JamesyCottony - 16/4/16 at 06:48 AM
I live near Chichester
I put some 20W50 in the dashpot and had to put my hand over the inlet to start it again.... and idle was rough and it kept on dying. I then (while it was running) adjusted the mixture and the revs raised, it became smoother and when i put throttle on its revs nicely and draws air in nicely, seem to be pretty sweet.
It got to temperature, the fan then kicked in
ian locostzx9rc2 - 16/4/16 at 07:33 AM
Glad you have got it running
JamesyCottony - 16/4/16 at 09:46 AM
I have noticed like a light brown sludge stuff coming into the coolant tank, would this just be old sludge that has built up due to lack of running? It's not sitting on the top, oil on dipstick looks nice
mark chandler - 16/4/16 at 09:55 AM
Probably just rubbish coming through, skim it off.
SU's are very clever devices, much underrated.
Once warmed up do as I suggested above, air filter off you can see the piston sitting just off its seat with engine vacumn, using a flat bladed screw driver insert in the gap between the body and piston and gently twist to lift the piston by 1/4" and if set correctly the revs may rise slightly or stay the same.
JamesyCottony - 16/4/16 at 10:04 AM
When the engine was spluttering the revs didn't move at all when I did what you suggested. Will try later on when I get home
Thankyou everyone for your help so far
britishtrident - 16/4/16 at 02:06 PM
10w/40 oil as 20w/50 causes problems in winter weather
Autotrans oil also works
