WANTED CAR TOWING DOLLY
teegray19 - 18/2/18 at 11:06 AM
As above,
If anyone has one and no longer needed, let me know.
Preferably close to NE40 but distance isn’t an issue.
Nickp - 18/2/18 at 02:38 PM
Daft question, but are you intending to tow on the road?
Do you know there are legal issues with transporting vehicles with these?
chris - 18/2/18 at 02:51 PM
https://www.ebay.co.uk/itm/SMC-Towing-A-Frame-2-6Ton-Car-Recovery-Dolly-Trailer-Heavy-Duty-Professional-NEW/220815299468?epid=1232298173&hash=item 33699e138c:g:JdQAAOSwo0JWJezs
i got one of these
Nickp - 18/2/18 at 03:05 PM
i got one of these
Doesn't the vehicle been towed have to be braked by law?
chris - 18/2/18 at 03:08 PM
if its good enough for motorhomers to use then good enough for me
Nickp - 18/2/18 at 03:11 PM
I'm no expert, but I'm sure there are legal issues with using them. I'm sure someone will be along in a bit with more info.
Owelly was done with a towing dolly and got points and a very large fine
Froggy uses an A frame but has it linked into his handbrake I think.
[Edited on 18/2/18 by Nickp]
loggyboy - 18/2/18 at 03:24 PM
Ok for emergency use. But anything being towed on a normal basis is classed as a trailer, so if it weighs more than 750kg then it should be braked.
rusty nuts - 18/2/18 at 03:49 PM
A lot of the motorhome ones also have a braking system on the towed car when the motorhome is braking.
froggy - 18/2/18 at 05:02 PM
Recovery type frame is as it says just for recovery . Current rules for towing using an a frame are that the towed vehicle if fitted with a braking system must work regardless of weight plus if the towed vehicle has power assisted brakes there needs to be a way of keeping the servo full or rather empty . My frame is an overrun type for towing behind a motorhome with a cable link to the foot pedal to apply the service brake . As there’s no way of proving the efficiency of this DVsa etc it just needs to satisfy the requirements. It’s easily found by searching towing a frame rules .
furryeggs - 18/2/18 at 06:39 PM
http://locostbuilders.co.uk/viewthread.php?tid=200959
Owelly. A frame court case.
I was going to get an A-frame for getting my tiger about and to IVA. I then read this and decided to rent a trailer when the time comes.
trextr7monkey - 18/2/18 at 11:16 PM
Saw one on the Carlisle buying and selling pages on Facebook Marketplace tonight if that’s close enough
Atb
Mike
owelly - 19/2/18 at 02:37 AM
Just to add, overrun brakes were outlawed in 2014 on trailers with axles over 1m apart, which includes cars on A-frames and dollies. Dollies and A-frames are for recovery of a broken down vehicles (there's a definition of those) to the first safe place....which on a motorway would be to the next exit ONLY or on a narrow lane, to the next wider stretch of road.
froggy - 19/2/18 at 08:14 AM
You got a link to that info welly? Gov uk is still showing the 2011 info regarding dollies and a frames
