Moorron
posted on 2/6/09 at 08:02 AM |
BEC oil consumption?
Hi lads hope your all out in the cars at the moment. After my last engine required topping up every time I went out I am now finding I spend far to
many moments checking my oil level on the new engine which is great fun as it’s a sight glass that’s not too easy to get to. But I am finding with the
new engine I am still filling up with oil as it does drop some AND I can smell burnt oil when out on the roads especially when slowing down through
the gears.
Ive always owned older cars where oil consumption seems to be much less then modern ones like the GF’s Ford Puma which uses a litre a month with heR
doing so many short distance journeys every day.
I also heard somewhere that the suggested oil loss in Kawasaki bike engines is 1 litre per 1000 miles but i am unsure if this is true or not?. I
understand my engine is not new so its going to have so wear and tear but I just need to know what to expect from it. Reading the manual for the bike
it tells you to keep the oil in-between the min and max marker on the sight glass which I could never see until last night when I could make out 2
little pips on the casing which I assume are these markers. All I did was keep it in the sight glass before this.
It took 700ml to fill the oil from min to max, but take into account I have a larger sump so it would be less on the standard bike engine however its
still ‘used’ this amount of oil within 300 miles.
Have I got a problem or should I just keep an eye on it and top it up from time to time?
cheers
Sorry about my spelling, im an engineer and only work in numbers.
Jon Ison
posted on 2/6/09 at 08:18 AM |
All the BECs I have had to date have used a little oil but not the amounts yours is, provided all is sweet no great big puffs of blue smoke then just
keep an eye on it.
Tip, got a camera phone ? Perfect for checking oil levels.
smart51
posted on 2/6/09 at 08:30 AM |
I have to top mine up regularly. I just keep some in the boot, together with a funnel, and top up when the daylight is just right to see the window.
I have a small mirror which I keep with me too so I can see the sight glass from above the engine.
skidude88
posted on 2/6/09 at 10:59 AM |
I'm the same, carry spare in the boot and top up regularly - Do get through a fair bit, but I gathered that was normal?
Early MK de-Dion CBR1000 FJ-FP.
ReMan
posted on 2/6/09 at 11:49 AM |
Yep, expect it to sip a bit, specially if caned
posted on 2/6/09 at 11:56 AM |
Our ZX12R uses a little bit of all but only needs topping up every once in a while. We have a mirror mounted at 45 degrees in front of the sight glass
which makes checking the level a bit easier.
Phil
Moorron
posted on 2/6/09 at 01:01 PM |
yeh i try and use one of those mirrors on the end of a stick thinks and a tourch but it aint easy. I might get a piece of polished stainless then and
make a fixed one.
posted on 2/6/09 at 02:20 PM |
My car has never used any oil, the only time I fill it up is when I do an oil change.....
gixermark
posted on 2/6/09 at 03:26 PM |
halfords do very handy inspection mirrors - on flexible metal pipe stuff !! its the best 5 or 10 quid i spent when i was running the later blade
engine with sight glass.. sometime a torch to shine light into the mirror helps too :-)
and yes - a glug or two each track day seemed fairly normal...
eccsmk
posted on 2/6/09 at 05:34 PM |
my zx12 uses a bit of oil its nothing to worry about.
i look the the gap where my drivers side wishbones are to check my oil
simples
dean100yz
posted on 3/6/09 at 01:03 PM |
Yeah my 918 uses a bit
Moorron
posted on 3/6/09 at 09:26 PM |
looks like some are and other arent.
I worked out that includinth e gearing difference and harder load on the engine from the bec and bike installation then its about right if this
1l/1000miles romour is right.
cheers
tootall
posted on 4/6/09 at 11:28 AM |
ive only driven my bec for a week n half and done about 400 miles i over fill oil to top of sight glass an its used to max mark prob about 400ml used
i was getting worryed to but it seems aceptable
some people dream of sucsess, others just get on and do it !!
