tdbracing
posted on 9/3/10 at 08:18 PM |
WHAT RADIATOR!!!
Hello Chaps
I am running a zetec 2.0 ltr Blacktop inMK and we are struggling to work out what rad to use that is small enough to fit but big enough to keep the
engine cool
the standard MK rad is £150 but we are hoping to get one cheaper that that
any advice would be great
thanks
fesycresy
posted on 9/3/10 at 08:22 PM |
Polo.
stuart_g
Nearly everyone uses the VW302 rad from a VW polo. Cost about £45.
NS Dev
posted on 9/3/10 at 08:31 PM |
Yep, 1.0 mk2 polo rad. fine for over 200hp in mine.
PS see yr in woodville, a local then!
I visit a chap in woodville fairly regularly, small world!
posted on 9/3/10 at 08:52 PM |
Polo or Micra rads both work are cheap and are well tested by builders
austin man
posted on 9/3/10 at 09:37 PM |
check ebay out I think GBS are selling the escort items for around 80 we have on running on a 2 litre silvertop no problems at all and it has seen a
few track days
James
posted on 9/3/10 at 09:49 PM |
Polo as above or Golf one which is 30mm or so bigger if you're worried.
About £35 online, maybe less.
HTH,
James
[Edited on 9/3/10 by James]
- Muhammad Ali
contaminated
posted on 9/3/10 at 10:01 PM |
I'm running a VW 302 as above.
tdbracing
posted on 9/3/10 at 10:09 PM |
Thanks All polo it is
if your in woodville send me a note and you can come and see the build
blakep82
posted on 10/3/10 at 12:02 AM |
about £35 (inc vat and post) for a mk2 polo rad from northern radiators
is it just me, or have there been a LOT more threads than normal about radiators the past few days?
________________________
posted on 10/3/10 at 08:16 AM |
Must be this crazily hot weather we've been having ![](/images//smilies/smile.gif)
tdbracing
posted on 10/3/10 at 01:56 PM |
thanks for the advice i will get one ordered.
Nice one ![](/images//smilies/bigsmile.gif)
tdbracing
posted on 10/3/10 at 02:02 PM |
I have sent you a u2u give me a call when you get a min
Stuart_B
posted on 11/3/10 at 08:56 PM |
i used a mk2 escort rad, they are about the same price as a polo, and are the ones mk sell, but they blank the top cap off, but i did not want to run
a header tank so it was perfect for me.
stuart
