907
posted on 10/3/10 at 08:43 AM |
Glue or Tape for ABS
Hi All,
I have bought an estate car as my "workhorse" but it looks really rough on the top of the rear bumper.
A previous owner had stuck a clear plastic protector strip on it which looked poo. Edges peeling up and
dirt had got under it in places.
When I removed it some of the paint came off so now it looks almost as bad.
All is not lost, as I have found (on eBay) an ABS bumper guard (new) that's moulded to fit the car.
The questions are what do you all recommend to fix it on with? (ABS to ABS? bumper)
Some sort of glue, mastic, or double sided tape? and where do I buy it from?
Cheers in anticipation.
Paul G
stuart_g
posted on 10/3/10 at 08:51 AM |
I would suggest Sikaflex or similar PU adhesive. Failing that a contact adhesive.
MikeR
posted on 10/3/10 at 08:57 AM |
are you ever likely to want to remove it?
Ie if it gets bashed will you decide it looks tatty and want to replace it?
If so i'd suggest double sided tape and maybe two coloured self tappers.
posted on 10/3/10 at 09:50 AM |
Gaffer tape, if it's a Mondeo it's almost obligatory round here
907
posted on 10/3/10 at 09:53 AM |
I went on the Sikaflex website and found there's loads of different types.
Which one?
I like the idea of tape. I've seen "Mounting Tape" in Halfords but I'm not keen on the self tappers.
Is there a "sticks like **** to a blanket" tape?
Pic below shows what I'm trying to do. (Pic on the left stolen from eBay)
Paul G
[Edited on 10/3/10 by 907]
![](/galpreviews/a1108886-bumper guard.jpg) ![Rescued attachment bumper guard.jpg](/gallery/a1108886-bumper guard.jpg) Rescued attachment bumper guard.jpg
adam1985
posted on 10/3/10 at 10:07 AM |
Paul G
not a tape but theres a glue one
Sticks like s**t
stuart_g
posted on 10/3/10 at 11:31 AM |
Hi Paul,
I would use Sikaflex 221. This alone has been used to bond the carbon mods stone guards to the wheel arches on my Westy. These are quite an odd shape
and it holds them in place no problem.
Sikaflex 221 can be bought from motor factors.
The trouble with tape is that rain will get underneath the panel and the sun will warm it up and eventually the sticky will go.
907
posted on 10/3/10 at 12:17 PM |
221 it is then.
Cheers everyone for all the replies.
Paul G
thunderace
please post a pic
plentywahalla
posted on 10/3/10 at 12:55 PM |
ABS should be solvent welded with acetone based adhesives
All solvent welded plumbing use ABS fittings and proprietory adhesives are available form all trade plumbing wholesalers.
Nail polish remover is basically acetone also.
indykid
posted on 10/3/10 at 01:44 PM |
you want vhb tape
like this
tom
[Edited on 10/3/10 by indykid]
907
posted on 13/3/10 at 11:47 PM |
I had to smile.
I bought a tube of Sikaflex 221 the other day and this morning the postie rang the door bell.
The bumper guard had arrived.
Took it out of the box to find it already has VHB tape on it....
And, two holes in each end that match the bumper mounting screws.
So, a squirt of super glue, maybe some Araldite, just to be on the safe side. ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Cheers all
Paul G
