Author: Subject: Omex 600 ECU plus full bike TB setup
stuart_g
posted on 10/3/10 at 07:03 PM Reply With Quote
Gauging interest in my complete TB setup as I'm thinking of going for a complete Jenvey kit and Emerald ECU.
The kit will include the following.
Omex 600 ECU, software cd and maps.
Full ECU spec HERE
Full wiring loom for injection and ignition. Water temp sender and air temp sender.
Complete GSXR 750 TB setup which comprises of a Burton inlet manifold, inlet manifold gasket, GSXR 750 TB's respaced and fitted to the manifold, Throttle position sensor, injectors, fuel rail and FSE Power boost valve/Fuel pressure regulator.
Picture of setup.
This setup is currently running very well on my car but it does as with all installs need a rolling road setup.
The ECU retails for about £600 - £650 and the loom is about £150 - £200
I would sell these for approx £550 +P&P
The complete TB setup would be £250 - £275 +P&P.
Any interest?
07891 588289 email or U2U.
Stu.
[Edited on 10/3/10 by stuart_g]
eddie99
posted on 10/3/10 at 07:47 PM Reply With Quote
If only this had come up for sale a few months ago. I paid a fortune for my ECU
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
johnH20
posted on 10/3/10 at 08:01 PM Reply With Quote
Hi,I can't help asking what you hope to gain from your proposed set up. What problems/shortcomings have you found?
stuart_g
posted on 10/3/10 at 08:14 PM Reply With Quote
I haven't come up against any problems with this setup.
My reasoning for going Emerald is that they are closer to me than any other tuning company/Rolling road and they have a new ECU coming out next month and I want some of the features that it has. As far as the TB's go, Jenvey are a tried and tested setup and should give the best results/performance.
If none of this sells then I will carry on and get it RR'd as is, that is why I am gauging interest.
I might just sell the ECU and loom, change to Emerald and keep the TB's.
will121
posted on 10/3/10 at 08:42 PM Reply With Quote
whats the new Emerald ECU got? i was looking at buying one this month
ChrisW
posted on 10/3/10 at 11:33 PM Reply With Quote
From Dave Walker himself:
My question
Finally, what advantages does the new ECU give?
Emerald's response
You will have on-board data logging, direct comms via serial port or USB plug. It is also fully water proof and has the facility later for knock sensing.
In other words, not a lot!!
Chris
stuart_g
posted on 11/3/10 at 08:21 AM Reply With Quote
Not too ure on the differences between the latest Emerald and the existing one but it has some features I want that the Omex doesn't have.
arrow-engineering
posted on 11/3/10 at 04:51 PM Reply With Quote
ecu
first dibs on ecu please, u2u sent. ta
