Westfield SEiW Megablade
SVA Sept 05 so on a 55 plate only 5200 miles
taxed end Sept , tested until 13th October 2010
Exterior
V8 bonnet, Detachable rear arches, carbon effect front wings, carbon stone protectors, carbon effect head lamps, rear lights and number plate lamp,
carbon lockable boot lid, carbon aeroscreen. Primary designs carbon fibre exhaust can.
Black Team Dynamics 15” wheels with fresh 195/50/15 yokohama tyres.
Interior
Westfield orange piped seats, 4 point Westfield harnesses, aluminium panelled tunnel with carbon fibre dash board,
Racetech suede removable steering wheel, push button start, Westfield instruments, self cancelling indicators, cut off master switch.
Engine
Honda fireblade RRW supplied and fitted by AB performance. Accusump, Westfield filter, motul oil cooler.
6 speed sequential gearbox, Barnett clutch springs, Electronic Flat change system, Westfield reverse box, Cosworth LSD and driveshafts.
Brakes
Westfield alloy hubs, Tarox grooved and drilled discs, wildwood 4 pot front callipers, braded brake lines
Box full of receipts, build pictures. The car was rebodied in late 07, simply due to colour change (original was yellow) I have owned the car since
Nov 2008, very recent oil change, plugs and WRB centre nut tightened and filled, plus general bolt check.
It does what it says on the tin ! very nice, tidy, reliable, quick car.
£10250.
Tim 07770747634
car is based in south Yorkshire
more pictures are here
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=9;t=81209
[Edited on 28/4/10 by tmo]
