Latest Products!
Just added a few more lines which may interest you!
[img]http://
[/img]
First off - super pocket size digital multimeter, comes complete with batteries & a transistor tester, leads, instructions all ready to use just
£5.95 with P & P of just £1.95
Does all the important things, like ohms, amps, volts & buzz test for continuity!
Next, AA size rechargeable batteries, but not any old rechargeables, these are 3000 mAh - Yes, that's right 3000 mAh, nearly double the capacity
of some rechargeables & obviously NiMh so no memory issues either - these are great for high current items such as cameras & motorised toys
etc & they're cheap too, just £5.45 for 2 batteries inc FREE P & P
[img]
[/img]
Next up AAA size rechargeables, again with a riduculously high capacity of 1800mAh, that's MORE than twice plenty of NiMh AAA size batteries,
same price as the AA's & same FREE P & P deal
Last but most certainly not least I have a storage cabinet or parts organiser. These are absolutely brilliant - I'm using them in my own workshop
& can actually see the bench for once instead of having it covered with myriad nuts/bolts etc
[img]
[/img]
These are just £21.95 + P & P of £4.95 .The cabinet is 490mm High, 300mm wide & 135mm deep, it has 40 draws measuring 120 x 55 x 35mm & 1
large drawer 270 x 120 x 35mm. I only have a few of these so get in quick!
Don't forget I'm still running a promotion on my new Webshop with a 10% discount if you type
LOCOST
as a discount code at checkout see
www.furoreproducts.co.uk
[Edited on 7/9/10 by russbost]
