Atspeed - Weber Fuel Pumps
This is the new fuel pump from Webcon.
Competitively priced, reliable, and almost SILENT in operation!
Ideal as an upgrade for noisy, unreliable square type fuel pumps.
Perfect for Short Circuit Oval racing, or classic cars/ hot hatches using Carburettors e.g. Weber DCOEs.
The pumps are fully sealed units with steel casings and a zinc plated and yellow passivated finish. Each pump is supplied with attached filter,
mounting bracket and Push-On 8mm O/D fuel pipe unions for both ends. Inlet and outlets are threaded to take the unions. Hose clips and 2 x 100mm
lengths of fuel line are also included.
The pressures available are:
WFP501 Electric Fuel Pump runs at 0.34 - 0.62 BAR (5.5-9.0 PSI)
WFP502 Electric Fuel Pump runs at 0.17 - 0.31 BAR (2.5-4.5 PSI)
Dimensions:
Length 172mm x Diameter 54mm
For More Details See Link Below:
Weber Fuel Pumps
We have fitted these to many short circuit oval race cars, autograss cars and kit cars.
£40 + vat
available to purchase online.
- colin.
[Edited on 1/10/10 by atspeed racing]
