stupott901
posted on 28/10/10 at 06:53 PM |
what engine
Well my blade engine in my Mk Indy has died I am know undeceided what engine to replace it with.
I am not sure wether to kep to a blade engine again for ease, but for drivability and ease of use im thinking of going to car engine,
so iam wieghing up my options
my question is which engine will be easiest and cheapest and to get all the bits for to go for car engine wise what im considering are:
Zetec (are those new ones any good on Ebay?)
Vauxhall Redtop
Rover K Series
and also is there anywhere i can get a complete engine package including transmission do any of the kit manufactuators do this?
many thanks for any help and advice given
big_wasa
posted on 28/10/10 at 07:05 PM |
its going to be much cheaper to stick another blade in it.
edit:
cec will mean buying everything like prop and exhaust. You could maybe use your bike carbs on it
[Edited on 28/10/10 by big_wasa]
DRC INDY 7
posted on 28/10/10 at 07:08 PM |
better of buy a nearly new blade engine it be cheap than car engine conversion
But if you do go car engine forget all that ford rubbish and fit a sr20det engine and box from a nissan 200sx
Puddle Dodgers Club
posted on 28/10/10 at 07:15 PM |
It might be worth checking your chassis dimensions and in particular the width at the front of the transmission tunnel. You might need some fairly
major chassis modifications to convert to CEC.
Also, to get a power/weight ratio comparable with the BEC, you'll need to make a few modifications to any of the engines you've
mentioned.
Personally I'd go for another blade engine, it's gotta be the most cost effficient route. And besides, why pay more money for a lower
powered CEC?
Phil
posted on 28/10/10 at 07:18 PM |
Will this one fit?
Timing seems rather apt.....
Phil
[Edited on 28-10-10 by Hellfire]
interestedparty
posted on 28/10/10 at 07:32 PM |
Indy chassis should be able to take a type 9 box ok, I'm almost certain the only difference in Indy BEC/CEC is the engine cradle itself.
So the OP would need a gearbox mount and engine mounts, plus a hole for the gearlever, maybe a different clutch aggangement, and a prop, of course,
although he could sell his current prop and the cradle to someone who was going the other way.
If the OP is ok with the BEC thing, though, then another blade engine has got to be the right way.
[Edited on 28/10/10 by interestedparty]
adithorp
posted on 28/10/10 at 07:58 PM |
"...so iam wieghing up my options ..."
You have no option but to go and wash your mouth out!
adrian
http://jpsc.org.uk/forum/
stupott901
posted on 28/10/10 at 08:07 PM |
Ok im getting the feeling the genreal concencous is for me to put another blade engine
and adrian i have washed my mouth out for even saying it
thanks for the advice
and phil cant see the link you posted as i am being a tight arse and havent contrubuted bummer lets hope it doesnt go
[Edited on 28/10/10 by stupott901]
posted on 28/10/10 at 08:13 PM |
Blade RRV engine for £200 in the 'For Sale' section....
Phil
stupott901
posted on 28/10/10 at 08:33 PM |
ok thats sounds bit of a bargain, i will u2u him and get some details cheers phil
