New Topic New Reply
Author: Subject: Acewell 3252 Now Available
russbost
posted on 16/11/10 at 11:12 AM Reply With Quote
I now have the latest Acewell in stock - the 3252, looks just like the 3250/3251 but has an orange backlight & has a gear indicator to tell you what gear you're in (calculated from roadspeed & revs)
[img] Acewell 3252
Acewell 3252
[/img]
So functions are:- Speedo, tacho (both digital & bar graph), fuel gauge, coolant or oil temp, volts, gear shift light, max temp light, clock, gear indicator. The display also has the facility to show n or r for neutral or reverse
In addition can be supplied with a warning light surround with all IVA warning lights & oil pressure light + either battery or neutral light
As pictured £139.99, with 8 warning lights£189.99, both prices plus P & P but LESS Locosters discount!
Comes with all sensors except fuel sender (uses existing) & all wiring harnesses/diagrams, instructions etc., go on, put it on your Xmas list!
New Topic New Reply
