arcwelding01
| posted on 16/12/10 at 03:08 PM |
240V Plasma Cutter £620.00
XTI 30P PLASMA CUTTER
£620.00 inc Vat & Carriage.
The use of inverter technology allows the construction of a lightweight portable plasma inverter machine which is ideal for sheet metal applications.
The variable output of the XTI 30P makes it ideal for cutting metals upto 6mm thick where the output power can be fine tuned to minimise dross on the
cut edges. The extended cutting nozzle on the torch ensures good visibility of the cut and its parallel sides make it ideal for following templates.
Consumable life is maximised by the torch having HF pilot start. Generator Friendly The XTI 30P is able to cope with inputs which fluctuate by +/-15%
and can be used with the majority of generators. The machine is housed in an ABS Plastic case with an integrated carry handle and shoulder strap.
Standards of Conformance ISO/IEC60974-1 ISO/IEC60974-6 RoHs compliant.
MAIN FEATURES INCLUDE
• 240V Input
• Lightweight 7.6 Kg
• 60% Duty Cycle @ 30A
• Generator Friendly
• Ideal for Sheet Metalwork
• 7mm Production Cut
• 10mm Severance Cut
• Supplied with XT30 Plasma Torch x 4mand 3m Earth Cable
• Auto Over Voltage and Over Current Protection
• Includes Air Pressure Regulator
• IP23
• ABS Plastic Case
• 12 Months Return to Base Warranty
