130Amp DC Tig Package £575.00
GYSMI TIG 137 HF DC PULSE
£575.00 Inc Vat & Carriage
Designed with INVERTER technology, the GYSMI 137 HF DC is controlled by microprocessor with a digital control panel.
Features
HF without contact or LIFT with contact starting.
Integrated automatism : This system helps you position properly the electrode before the current increase. A very low intensity is supplied (10A),
acting like a beam of light . (only available in 4T and 4Tlog)
3 tigger controls : 2 Times, 4 Times, 4 times "LOG" where the operator chooses between 2 welding intensities (hot current or cold current)
at any time by a short pulse on the trigger.
Easy Pulse Mode: The operator defines his average welding current. The welding unit automatically regulates the frequency, the hot current and the
cold current.
TIG Spot : Enables to prepare the parts thanks to spot welding.
5 Memories : In order to save your chosen programs and your presettings.
MMA very easily welds with every electrode steel, stainless steel, cast iron, rutile or basic.
Anti-Sticking process: this product offers you an adjustable Hot Start, easier start for all types of metal (low Hot start, for thin metal sheets high
Hot start for metals that are difficult to weld, dirty or oxidized parts.
EN 60 974-1 MADE in FRANCE
