New Topic New Reply
Author: Subject: Flanges, Bike Carb & Throttle Body Manifolds etc
FASTdan
posted on 1/3/11 at 11:19 PM Reply With Quote
New post for a new year. Laser/Waterjet Cut manifold flanges available as follows:
Ford:
1.8/2.0 Zetec Inlet Flange (10mm Alu)
1.8/2.0 Zetec Inlet Flange (8mm MSteel)
2.0 ST170 Zetec Inlet Flange (10mm Alu)
1.8/2.0 Zetec Exhaust Flange (8mm MSteel)
1.8/2.0 Zetec Exhaust Flange (10mm St St)
1.6/1.7 Zetec SE Inlet Flange (10mm Alu)
1.6/1.7 Zetec SE Inlet Flange (8mm MSteel)
1.8/2.0/2.3 Duratec Inlet Flange (10mm Alu)
1.8/2.0/2.3 Duratec Inlet Flange (8mm MSteel)
1.8/2.0/2.3 Duratec Inlet Flange (10mm St St)
1.8/2.0 Pinto Inlet Flange (10mm Alu)
1.8/2.0 Pinto Inlet Flange (8mm MSteel)
1.3/1.6 Crossflow Inlet Flange (10mm Alu)
1.3/1.6 Crossflow Inlet Flange (8mm MSteel)
1.4/1.6 CVH Inlet Flange (10mm Alu)
1.4/1.6 CVH Inlet Flange (10mm St St)
Vauxhall:
C20XE & C20LET Inlet Flange (10mm Alu)
C16SE Inlet Flange (10mm Alu)
I am able to supply complete aluminium inlet manifolds and Self weld MS inlet manifolds for the fitment of bike carburettors or throttle bodies to any of the above engines. I have a large range of standard designs or if required a manifold can be made to your required dimensions.
I also stock several sets of carbs for anyone looking for a complete manifold/carb package, as well as our standard 45/48mm fluro lined silicone hose kits.
Please see my homepage as in my sig where you will find links to the ebay site for pricing and also the Facebook page where you will find further info and many drawings.
I can also offer 3D and 2D CAD services and small fabrication work. Please contact me for further details.
Thanks for reading,
Dan
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
New Topic New Reply
