Author: Subject: Landrover engine mounts (vibration)
rich201283
posted on 21/3/11 at 07:26 AM Reply With Quote
I have a 2.0 zetec, I have used landrover mounts but i seem to be getting a lot of vibration, Think they maybe to hard, I have checked to make sure nothing is touching the chassis.
One thing i did check is that my brother is using sierra mounts, Are these softer?
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 21/3/11 at 08:20 AM Reply With Quote
There are different types of Landrover mounts, the competition ones I used to have on my special were virtually solid. It is possible you have aftermarket ones.
Cannot comment on Sierra ones sorry, but in all my BEC's the engines are solid mounted and vibrations are not TOO bad, are you sure it is down to the mounts?
I would have thought it would only be an issue on start up and very lumpy cams?
If it is easy, try disconnecting the drive shaft and running the engine, see if the vibrations are from there?
Mr Whippy
posted on 21/3/11 at 08:59 AM Reply With Quote
I used the Transit engine mount as its made from very soft rubber, can't even feel my lumpy pinto running and the cars so much quieter
Size wise they are slighty wider but about the same thinkness as a landy one. you can dig your nail into the rubber its that soft
[Edited on 21/3/11 by Mr Whippy]
rich201283
posted on 21/3/11 at 09:23 AM Reply With Quote
What year transit and which engine where they off?
[Edited on 21/3/11 by rich201283]
Mr Whippy
posted on 21/3/11 at 09:30 AM Reply With Quote
86 - 91 very common type
here's a link, I have bought a few things from them and they are good to deal with
link y
dhutch
posted on 21/3/11 at 02:17 PM Reply With Quote
Where are the mounts placed, that effects it a lot. You want to allow movement in the right driection but prevent it in others.
