Spacers and other misc turned parts
If you need anything turning up for your build, whether its stainless or aluminium spacers, adjuster links, hubs, pulleys or whatever I can probably
do it.
There are a few examples of my work here:
http://customworkshop.co.uk/page2.html
If you need anything ask away.
Lead times are normally 2-3 weeks depending on material and tooling requirements.
I try to keep prices down to a minimum for all LCB members.
Spacers from £1.25 each
Tapped spacers from £1.50 each
Blanking plugs for throttle bodies from £10 set
Anything with bizarre threads or hole sizes isn't normally a problem and I can usually source something to suit. But give me a shout and
I'll see what I can do.
Sera
http://www.motosera.com
