jlayton
posted on 17/7/11 at 11:06 AM |
bec problems
as above having some minor problems with my k3 gsxr 1000. when im cuming down the gear box on the way to a junction once in a blue moon the revs drop
to zero but obviously it pumps straight away. this only happens when cuming down the box. also 9 times out of 10 when i select neutural at some lights
etc the engine cuts out then i have to fire it back up
any help would be great
jlayton
posted on 17/7/11 at 01:32 PM |
anyone got any idea's where to start looking
danny keenan
posted on 17/7/11 at 01:33 PM |
have you got any fault codes coming up on the dash?
jlayton
posted on 17/7/11 at 01:37 PM |
iv owned it for about 2 months now and the f1 as been on, but was told thats because of the exhaust system on it, never caused and problems before?
mad-butcher
posted on 17/7/11 at 03:41 PM |
Sounds a bit like fueling, get the same thing occassionally when I've been thrashing it on the motorway, one of those things I just live with,
I've put it down to fuel being evaporated in the float bowls after a fast run seems to settle down once the engine has cooled off a bit. hope
that makes sense.
tony
danny keenan
posted on 17/7/11 at 03:45 PM |
if i was you i would check to see what fault code you have got when the f1 light is on.
if you need to no how to get rid of the faults with the exhaust etc send me a u2u
thanks danny
jlayton
posted on 17/7/11 at 04:37 PM |
thanks danny
it has a power commander and was set up by mac 1, so would of thought i would not of had problems like this. ( i have changed the battery recently,
would this of caused anything ????)
