Author: Subject: 893 fireblate oil temp sensor
Ian Jones
posted on 22/2/13 at 05:40 PM Reply With Quote
Hi all
does anyone know where I can put a oil temp sensor into the engine please on a 893cc fireblade engine.
the current one is in a adapter with a oil pressure sensor that is on a stainless flex hose away from the block, so the temp doesnt not rear correct on the digi dash
thanks
ian
Jon Ison
posted on 22/2/13 at 05:43 PM Reply With Quote
I have mine in the sump, had a lug welded on then drilled n tapped it.
Ian Jones
posted on 22/2/13 at 05:47 PM Reply With Quote
im running a billet alloy sump if that makes any difference?
is there any removeable bolts/caps on the block that it will fit?, or where the standard one would be?
bigfoot4616
posted on 22/2/13 at 07:48 PM Reply With Quote
i was using a billet sump on my old 919 blade. on that it was just drilled and tapped through the side of the sump
HappyFather
posted on 22/2/13 at 11:02 PM Reply With Quote
I'm building an Aries and have also that adapter at the end of the flexi. I was getting incorrect readings (with cold engine, only started it a hand full of times) but fixed the problem by correctly earthing the adapter. It has a small bolt to connect a wire to. Earth the other end of the wire and it may fix your reading problems.
It's worth a try before spending money in other options.
Kind regards,
HappyFather
IainL
posted on 23/2/13 at 11:42 AM Reply With Quote
Originally posted by HappyFather
Kind regards,
HappyFather
Hi HappyFather,
I have the same set up as you and it's earth as mentioned above, but I still get very low oil temperatures as there is no flow of oil and it's far away from the engine.
Sounds like the way over this is to drill and tap the sump (I wish I thought of this when I fitted my new sump a few months back), another job to add to my list of mods.
Iain
HappyFather
posted on 24/2/13 at 01:55 PM Reply With Quote
Hi, IainL
Thank you for the info. I guess I'll have to look for the parts to do that drill&tap. I'll eventually have to drop all the oil in the engine (it was from the bike and is with me since 2010) and will take the chance to do that mod.
Cheers!
HappyFather
Ian Jones
posted on 22/3/13 at 07:30 AM Reply With Quote
Did you have any pics of where you done it please
bigfoot4616
posted on 22/3/13 at 06:48 PM Reply With Quote
no pics and i sold it so can't get any.
as the engine sits in the car it was on the front face of the sump, and i think about half way along(not entirely sure on this bit as its over 18 months since i've seen it)
