4 Wheel Laser Alignment System
This 4 wheel laser alignment system uses a unique 5 laser design for increased ease of use, which facilitates 4 wheel alignment check and adjustment
for Toe-In, Toe-out angle and thanks to the 5 lasers Thrust angle as well.
The only product with dual mounting options; a simple to fit design that moves with the wheel, which does not need manual re-positioning of the gauge
to keep it flush to the wheel rim after each adjustment.
Alternatively by sitting the TrackBar flat on the floor it can be used on very low cars like the Westfield XTR which has only 65mm ground clearance.
Tested and used ona wide range of vehicles from low profile sports-cars, to 4x4s with large tyres. The gauges rest on the wheel rim for accurate and
consistent readings.
Buy Now
Patent Pending: GB1310710.7
