New Topic New Reply
Author: Subject: New danST Velocity Stacks
FASTdan
posted on 23/6/13 at 09:24 AM Reply With Quote
We have expanded our trumpet/velocity stack range to incorporate a 50mm bore parallel trumpet in both 50mm and 90mm lengths. These are lightweight spun aluminium trumpets with a standard jenvey/weber type flange fitment (65mm centers).
They are primarily designed for use with our CNC clamp rings for mounting on the GSXR range of throttle bodies and being 50mm diameter suit the 750/1000/1300 bodies perfectly.
The flange can of course be removed should you wish to use these trumpets for other applications.
90mm:
50mm:
Clamp Ring system:
Fitted to a set of GSXR1000 Throttle Bodies, respaced and mounted on a Zetec Inlet:
The 50mm trumpets are priced at £15 each. Please contact for further information and prices on the clamp ring system as we have various options to suit different applications.
Don't forget, we also stock 40mm and 45mm dia cast (machine finished) jenvey/weber trumpets too (50mm long), shown here fitted to GSXR 600 throttle bodies with integrated pipercross plate:
Thanks for looking.
danST
[Edited on 23/6/13 by FASTdan]
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
New Topic New Reply
