IainL
posted on 23/6/13 at 07:52 PM |
Few Bits For Sale
5 speed sierra gearbox with mount, bought as a spare and never used. looks ok inside and oil drained out was clean. Rubber mount will require
replacing. £130
![](/galpreviews/gearbox int.jpg) ![Description](/gallery/gearbox int.jpg) Description
![](/galpreviews/12gearbox.jpg) ![Description](/gallery/12gearbox.jpg) Description
M16 calipers and vented discs, calipers are fitted with spacer kit to suit the discs were in working order when removed from car, but that was a
couple of years ago. discs have surface rust and will require cleaning. £40 - SOLD
![](/galpreviews/7calipers.jpg) ![Description](/gallery/7calipers.jpg) Description
Wheels 13x7 ford fitment fitted with old Michelin slicks 3 ta00 and 1 ta20, the tyres are old and starting to perish, the ta20 quite badly. would be
ok or a trackday or drifting etc, wheels are off a rally car and do have scratches and nicks etc but are ok. £160
![](/galpreviews/15wheels.jpg) ![Description](/gallery/15wheels.jpg) Description
All the above are located in Stonehouse, Gloucestershire (GL10)
Iain
[Edited on 24/6/13 by IainL]
TimC
posted on 23/6/13 at 08:36 PM |
Iain,
Any idea what offset the wheels are?
Tim (Blakeney, Glos)
Brook_lands
U2U sent re discs and calipers
daveb666
posted on 24/6/13 at 06:56 AM |
Also interested in the wheels depending on off set.
IainL
posted on 24/6/13 at 06:59 AM |
Daveb666 & Timc - I'll try to find the offset later today
Iain
IainL
posted on 24/6/13 at 06:08 PM |
Iain
I think ET is 10, worked out by doing the following measurements - Distance between the outer wheel rim and inner wheel rim is 200mm, the distance
from the back of the mounting face and inner wheel rim is 90mm
Hope the above helps
Iain
daveb666
posted on 24/6/13 at 07:04 PM |
Too low for me if its correct. No markings on the back of the spokes to be sure?
yellowcab
posted on 24/6/13 at 07:50 PM |
also keen to know the exact offset - not treading on anyones toes, as we're all after different offsets lol
IainL
posted on 24/6/13 at 08:04 PM |
Unfortunately had a good look and can't find anything stamped on the wheels to confirm the offset
Iain
IainL
posted on 27/6/13 at 04:22 PM |
Just noticed that ET should of been "minus" 10
Iain
IainL
posted on 21/7/13 at 04:07 PM |
Wheels and tires still available now reduced to £100
Cheers Iain
