Ian.C
posted on 17/8/13 at 08:22 AM |
Pinto engine
I have 2.0 pinto removed from a MK2 RS2000 apparently put together by Blackpool race and rally it comes with a RS sump that has a plate welded to the
bottom and ally engine mounts,lightened flywheel and clutch, electronic dizzy, twin 40 webers, fuel regulator,burton cam cover. Its got a few bits
missing, alternator bracket and dipstick. I am asking £500 it and the location is in cleveleys in Lancashire.
omega0684
posted on 17/8/13 at 09:41 AM |
might be worth sticking the spec of the internals up as well,
Ian.C
posted on 17/8/13 at 10:06 AM |
As far as I know it has standard internals, the camshaft is a high lift one but the engine builder ground the identification off the cam?? It also has
a vernier pulley.
Not Anumber
posted on 17/8/13 at 12:52 PM |
Its worth putting a bit more about the engine such as bhp figures and build information. As you know the identity of the original engine builder it
would be worth asking them to look up the spec as they are likely to have a record of the engine number.
As you will have gathered from looking at older posts on here, pinto engines tend to fall into 3 distinct price categories.
1. Recently rebuilt performance engines. Go for good money but spec and history is absolutely key.
2. Engines suitable for rebuild
3. standard engines in running order
The only real money is in the first category.
snapper
posted on 17/8/13 at 02:36 PM |
As it stands the cam cover, ally sump and 40's are worth the money
The fact that its running 40's means the bhp ain't much over a standard RS2000 or it would need 45's
I eat to survive
I drink to forget
Ian.C
posted on 17/8/13 at 09:07 PM |
You are probably correct, I will strip the engine and sell the parts seperately.
bigbri
posted on 3/9/13 at 04:54 PM |
Hi, Its Brian,
I'm interested in the engine, i was just wondering whether or not its still for sale?
