Author: Subject: led shift light
beaver34
posted on 25/4/14 at 09:20 PM Reply With Quote
led shift light
want to add a nice led shift light into the dash
my ecu has an output for it, i like the look of the ones that you get on new bikes with afew led's in
had a quick look on ebay but that seems a minefield if you out led bulb into it!
any ideas on where to source one?
ta
daveb666
posted on 25/4/14 at 09:30 PM Reply With Quote
I used a maplin LED cluster, fiver iirc. Lights using my ECUs output and is vv bright.
beaver34
posted on 25/4/14 at 09:33 PM Reply With Quote
cool, will take a look there
thanks!
beaver34
posted on 25/4/14 at 09:37 PM Reply With Quote
like this one?
http://www.maplin.co.uk/p/26mm-redgreen-led-cluster-pd00a
daveb666
posted on 25/4/14 at 09:39 PM Reply With Quote
Yep that's it. Tried to send you a photo of my light intall on Facebook but dunno if it worked.
Ben_Copeland
posted on 25/4/14 at 09:42 PM Reply With Quote
Originally posted by beaver34
like this one?
Same as mine. Bargain price
Ben
Locost Map on Google Maps
Enter Your Details Here
beaver34
posted on 25/4/14 at 09:43 PM Reply With Quote
nope it didnt post it in the lcb north bit
looks smart for the money anyway
Scuzzle
posted on 25/4/14 at 10:31 PM Reply With Quote
I use the Ecliptec shift-i
https://ecliptech.com.au/
It's very good but not cheap, around £100
[Edited on 25/4/14 by Scuzzle]
beaver34
posted on 26/4/14 at 12:38 PM Reply With Quote
I had one of those was great
i do have a race tehonolgy dash 2 in the car, but its in the centre and the engine revs so fast and stuff happens so quick i dont always see it hence the want for a single shift light behind the wheel
fishachuck
posted on 28/4/14 at 02:14 PM Reply With Quote
Hi Sorry if i'm hijacking but could you help me with the wiring, it as white/green/red wires, do you need to connect them all.?
many thanks
Ben_Copeland
posted on 28/4/14 at 02:24 PM Reply With Quote
I can check when I get home. But you've got 12v and 2 negative switches. So the Ecu grounds one wire (green light), then the second wire(red light)
Ben
daveb666
posted on 28/4/14 at 02:37 PM Reply With Quote
As Ben says, my ECU only has one shift-light output so I have connected both the negative wires together. This lights the green and red LEDS together.
[Edited on 28/4/14 by daveb666]
fishachuck
posted on 28/4/14 at 02:41 PM Reply With Quote
Yeh my ECU only as the 1 wire for shift light so i'll give that a try, many thanks
