Gear Monkey
posted on 13/5/14 at 07:32 AM |
diy steering column and general weight loss
Hello guys,
Anyone made there own column? I'm looking to trim weight from all the little bits here and there and can see potential to lose a few lbs from
the column. Are there IVA rules and regs (I assume there are) that apply and that I should work around? This would allow me to use a minimal more
direct approach and the use of lighter materials. I have no need for adjustability as the only drivers will be me and my brother so building
everything around our dimensions.
Also what other components will help to trim weight? Any lighter racks out there that work well? I'm targeting as close to 400kg as possible.
Paul
snapper
posted on 13/5/14 at 07:51 AM |
IVA requires collapsable section and column offset so it does not punch through your chest
Usualy needs 2 universal joints
Rack outers are usually alloy, inners have to be steel
I eat to survive
I drink to forget
blakep82
posted on 13/5/14 at 08:02 AM |
Mmm, not quite, as I remember. Theres no requirement for a collaping section, although it is a very good idea
The manual has a list of safety features which are accepted, and requires at least one, but has to be well designed
Collapsible is one, 2 offset universal joints (each offset by at least 15degrees) is another. Either should be ok, both is obviously better
The manual is free to download and linked below. You really should be reading it before building and know it inside out. I used to but My build has
taken a bit of a stall, so I've not kept up with any recent changes
________________________
mcerd1
posted on 13/5/14 at 08:36 AM |
^^ as he said, there are other ways round this without using the collapsible column from a donor (see the IVA manual)
but its got to be better with both (afterall you've only got one chest!)
the column doesn't weigh that much compared to the rest of the donor bits so I'm be looking elsewhere for the weight saving (unless you
find a donor with lighter collapsible column)
[Edited on 13/5/2014 by mcerd1]
loggyboy
posted on 13/5/14 at 08:43 AM |
Raw do a basic column, its still IVA compliant:
I suspect its made up of Rally design components or similar.
Mistral Motorsport
FuryRebuild
posted on 13/5/14 at 08:45 AM |
Hmm -I could see a carbon fibre column and steering wheel would be great - more feedback from the wheels, and mass reduced from up-high.
www.furyrebuild.co.uk
The Black Flash
posted on 13/5/14 at 10:17 AM |
Agree, it's one of the last places I'd be looking to save weight I think. Can't see you'd save much on the bits in the engine
bay really, it's just some splined steel bars, what else is there to use?. Maybe on the upper donor part, if you used some lighter material,
but you'd want to make absolutely sure it was strong enough and probably end up overbuilding it just to be sure. Would you do better than the
manufacturers with all their years of testing and know-how?
mcerd1
posted on 13/5/14 at 11:00 AM |
IVA manual:
3- The steering control and column assembly must provide adequate
protection to the driver by absorbing energy from a driver-steering
wheel impact. This is the case if the steering control has an
approval (evidence may be markings or documents), or is similar to
an approved steering control. The vehicle should be assessed
using the material in Annex 1.
4- The vehicle and steering column assembly must be designed such
that in the event of a frontal impact at 48km/h (30mph) the rearward
horizontal displacement and vertical displacement of the top of the
steering column and its shaft do not exceed 127mm. The vehicle
should be assessed using the material in Annex 1.
Annex 1 goes into a lot of detail - these are the highlights...
"An offset between the steering column and the input shaft of the steering rack or box:
In cases where an intermediate shaft is used, it will be connected to the steering column at one end and the steering rack or box at the other, by
means
of universal joints and/or flexible couplings. The greater the angle through which the joints run, the more effective they will be in preventing
movement
being transmitted up the steering column. While it is unlikely that joints of this type will work at angles above 30 degrees, they are unlikely to be
effective
if the angle between the steering column and the intermediate shaft (when viewed from the side or the top of the vehicle) is less than 10
degrees."
"A telescopic intermediate shaft:
This is a common arrangement and may take the form for example of a sliding splined shaft, a sliding clamp arrangement on a non circular shaft
(e.g.
triangular), or a device that permits disengagement of the upper column from the lower column."
"A collapsible element in the upper column:
This may take many forms. Expanded metal tubes or convoluted tubes (in association with sheer pins in the column shaft) or sliding splines are three
of
the most common. These are designed primarily to allow the steering wheel and column to move away from the driver while absorbing some of his or
her deceleration if the driver were to hit the steering wheel."
Note: Driver impact against the wheel is still possible even when wearing a seat belt, particularly a fixed type rather than an inertia reel
type.
DW100
posted on 13/5/14 at 11:24 AM |
Think I'd be more worried about safety than weight in this area. Is this not how Ayrton Senna died?
trextr7monkey
posted on 13/5/14 at 01:26 PM |
Coozer's your man for this stuff as he used to make them professionally'
hth
Mike
Gear Monkey
posted on 13/5/14 at 09:32 PM |
Thanks for all the help guys. I've downloaded the IVA pdf which will come in very useful. I'm thinking of mounting the final section
horizontally to place the steering wheel at 90 degrees. I'll make this section short to suit the regs and then run 2 UV joints at 15 degrees or
more to the rack......Well that's the plan.
I'm looking to trim weight however small from all the components used as hoping to stay as close to 400kg as I can.
Thanks again
Paul
DIY Si
posted on 15/5/14 at 08:55 AM |
I'd be wary of putting the wheel vertical, you'll find it horrible to drive as your wrists have to do a lot more work. Ideally, it wants
to face you, so tipped back at the top slightly.
Sun Tzu, The Art of War
Gear Monkey
posted on 15/5/14 at 02:08 PM |
Thanks, I'll make a mock up to get it just right. I guess things like wheel position and pedals are worth spending a bit of time on to get just
right.
Paul
DIY Si
posted on 16/5/14 at 07:08 AM |
If at all possible, it's a good idea to build in a little bit of adjustment where you can. Whilst you may set the car up for you, with a certain
seat and certain shoes on, should anything change being able to alter the position of the pedals and the wheel easily is never a bad thing.
Likewise, somewhere to rest your left foot can be invaluable. Many complain that their left leg goes dead/knee aches etc as they have to just have
their foot floating. A little dent/bump on the tunnel panel or a bar across the floor can stop all that.
Gear Monkey
posted on 20/5/14 at 10:37 PM |
Thanks for the help guys, I've managed to get hold of a lightweight collapsible column from a Porsche 911 ![](/images//smilies/smile.gif)
