snakebelly
posted on 22/10/14 at 06:28 PM |
Come on then you lot, what's this?
Recently had the opportunity to clear out the Sheds of an old chap in Birmingham for his family. 3 Transit Loads later including 2 FOBCO drills (I
already have one I'm rebuilding) and some quite nice rare bits and pieces, i.e. Sturmy Archer bits.
But in amongst some other bits n bobs I found this, Google isn't much help, anyone seen anything like it before?
The label reads DSWH1 in the top right hand box and volts 230/50 in the bottom left and 30 watts in the bottom right.
Early single cup heater?
blakep82
posted on 22/10/14 at 06:34 PM |
Iron
Edit, I can't work out how exactly, but dowsings, with that logo made electric irons
[Edited on 22/10/14 by blakep82]
________________________
snakebelly
posted on 22/10/14 at 06:35 PM |
to iron what though!
splitrivet
Heater for a propagation tray ???
Bob
splitrivet
posted on 22/10/14 at 06:40 PM |
Aha what do I win.linkydink
Bob
tegwin
That... is a heated bog roll holder... hmmmm
www.verticalhorizonsmedia.tv
snakebelly
posted on 22/10/14 at 06:43 PM |
Or possibly a haemorrhoid treatment device? :-)
snakebelly
posted on 22/10/14 at 06:44 PM |
Bob
Nothing! don't think that's even close, this doesn't have a bulb for a start!
sickbag
posted on 22/10/14 at 06:46 PM |
UV or IR lamp?
Finally back on the job!
ReMan
posted on 22/10/14 at 06:47 PM |
Its would appear to be an immersible heater element, exactly for what though?
Would appear Dowsing made various thing with electrical heated elements in them so this fits their repatoir.
Sealing wax? Something that didn't need boiling at only 30W
www.plusnine.co.uk
snakebelly
posted on 22/10/14 at 06:48 PM |
don't think its a lamp, the long probe bit is metallic and chromed.... oh and the wiring is far too old for me to rick plugging it in!
snakebelly
posted on 22/10/14 at 06:49 PM |
Hence my original early cup heater quip :-)
splitrivet
posted on 22/10/14 at 06:53 PM |
That Dowsing gadjee made loads of heater doodahs entering it in google came up with that patent but looking at it Dowsing didnt have owt to do with
it.
Could be a sump heater.
Bob
Smoking Frog
posted on 22/10/14 at 06:56 PM |
A willy warmer, warmer.
RichieW
posted on 22/10/14 at 07:00 PM |
Reminds me of a bigger version of the heating element on my mam's old Carmen Rollers for doing her hair back in the 80s.
mark chandler
posted on 22/10/14 at 07:04 PM |
Early sex machine, later variants included a push pull movement.
Failing that it has a keyhole fixing on the base, is it used for heating home brew beer?
[Edited on 22/10/14 by mark chandler]
splitrivet
posted on 22/10/14 at 07:06 PM |
Sheep defroster, insert anusly into said frozen sheep and hay presto 5 mins later a toasty sheep.
Bob
[Edited on 22/10/14 by splitrivet]
Trollyjack
posted on 22/10/14 at 07:16 PM |
Looks like a heater to heat up bearings before fitting on a shaft
TrollyJack
JMW
posted on 22/10/14 at 07:30 PM |
What it's sat on
I'm more impressed by what it's sat on. Does the other side have the timing for G45s, G50s and 7Rs? That would be even more impressive.
AdrianH
posted on 22/10/14 at 07:33 PM |
As they did a lot of irons for snooker tables/billiard tables etc. I wonder if it was to iron inside the pockets?
The tube does look like it would be the heater, and chromed to be smooth
What is the inside face look like when hung up on the wall?
Adrian
Why do I have to make the tools to finish the job? More time then money.
gremlin1234
my guess is photographic processing, note also the 'probe' would be vertical downwards, (see keyhole slot on base/ back)
bi22le
posted on 22/10/14 at 08:00 PM |
Diesel tank preheater?
Mini space heater
Glove dryer
Please read my ring story:
gremlin1234
posted on 22/10/14 at 08:02 PM |
or perhaps, an aquarium heater
Rod Ends
posted on 22/10/14 at 08:06 PM |
It's for warming up a tin of grease to increase the viscosity and make easier to handle.
ReMan
Is there no chaffing (ooer mrs) or liquid marks on it as evidence of it being used for anything?
www.plusnine.co.uk
