baldthreads
posted on 21/5/16 at 09:26 AM |
5/8inch hole high angle spherical bearing for tca?
Im looking for some 5/8inch hole high angle spherical bearing for tca what do you all use ot dose anyone have any
prawnabie
posted on 21/5/16 at 09:28 AM |
Try Mcgill motorsport, they seem to be the authority on these
Shaun
minitici
posted on 21/5/16 at 09:44 AM |
To get high misalignment angles on rod ends it is usual to fit special bushes into the bore of the rod end.
In the case of a 5/8" bore, a 1/2" bolt is used.
If you needed a 5/8" bolt you would probably need to use a 3/4" rod end to accommodate the high misalignment bushes.
gallons perminute
posted on 22/5/16 at 09:56 AM |
http://race.parts/Catalogue/Bearings-Rod-Ends/Spherical-Bearings-Imperial/NMB/ABT-NMB-Imperial-High-Angle-Spherical-Bearings
Try here.
