robinsoncrusoe55
posted on 7/5/17 at 10:05 PM |
Home cctv system
In the market for a cctv system.... 4 cameras good quality etc
Can anybody recommend any particular ones, or even ones to avoid !
Any hints on what I should be looking for quality wise.... thanks
hearbear
posted on 7/5/17 at 10:48 PM |
Can't recommended any but don't fall into the trap of mounting the cameras high looking down as all you see is the top of the burglar and
not the important part the face view.
3.9Ltr SSC Stylus should be fun
stevebubs
posted on 7/5/17 at 11:23 PM |
Agreed on the camera locations.
I went homebrew with BlueIris and find it great.. uses a variety of IP Cameras (so you can use different types in different areas) and just installs
on an old Windows Box. Can also be set to just record based on movement which is awesome.
[Edited on 7/5/17 by stevebubs]
hkp57
posted on 8/5/17 at 02:53 AM |
Last year I fitted an 8 camera system from www.domar.com which were 5MP cameras which I cant fault.
I Installed all the hardware then through a remote access portal Domar configured it all.
https://domar.com/buy-4-zxtech-5-megapixel-ultra-hd-5mp-cctv-cameras-cloud-ip-poe-security-system.html
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
ReMan
posted on 8/5/17 at 10:16 AM |
I also bought my kit from Domar. good price/quality/service
One thing I would say, its that as hkp57 post, they can be fiddly to set up if you are not network/pc savvy. (Generally, not a Domar gripe)
I recently replaced my Box (retained the existing cameras) and its working great , but I still haven't got remote web-access fixed yet!
www.plusnine.co.uk
robinsoncrusoe55
posted on 8/5/17 at 07:21 PM |
Home cctv system
Many thanks to all for the advice and tips etc.
Never considered putting the cameras lower, for a better image/shot !!
Obviously, need to think about it.
A big thanks again to all !!
gremlin1234
posted on 8/5/17 at 08:04 PM |
for any remotely accessible cameras, (or any other systems!) ensure you change from the 'default' passwords.
robinsoncrusoe55
posted on 8/5/17 at 08:52 PM |
home cctv system
All good advice !!
Many thanks for that
loggyboy
posted on 9/5/17 at 07:47 AM |
Watch for misleading resolutions, a lot of kits listed as HD have the ability to record in HD, but the cameras will be lower spec. or vice versa.
Mistral Motorsport
splitrivet
posted on 14/5/17 at 09:14 AM |
Depend whether you want an IP based system or analogue.
The newer analogue using either AHD or TVI formats are fast moving up in resolution, personally I think the IP based systems are easier to install run
a patch lead to the camera and off you go and image clarity can be stunning but the kit is dearer.
A lot of kit out there is sold as HD but if you look at the spec the cameras are only 960h whereas resolution on the true HD cameras is 2.4 megapixel
or even 4 Megapixel on the latest cameras.
If you u2u me the spec your after I can sort you a price.
Regards,
Bob
