number-1
posted on 19/3/18 at 12:08 PM |
BEC ballast resistor?
Can anyone tell me why a BEC needs a ballast resistor fitted to make sure the engine turns off? Why does it not need it when on the bike? Or am i
missing something? From my understanding is even with the engine switched off, theres enough power from the reg/rec to keep the engine running. Why
doesnt the regulator/rectifier keep the bike running when switched off at the handlebars on the bike?
N1
CosKev3
posted on 19/3/18 at 12:28 PM |
Never heard of one being fitted!
I've got a R1 in mine,my m8''s built ZX9/R1/ZX12 BEC's and never had to do anything as you suggest
gingerprince
posted on 19/3/18 at 12:43 PM |
That doesn't make any sense - as soon as you turn the ignition off, the ECU and coils are disconnected, so there's no spark, so the engine
stops. So the reg/rec will only be feeding (for the fraction of a second the stator is still generating AC) the battery and not the main 12V feed.
theconrodkid
posted on 19/3/18 at 12:58 PM |
you talking about the one on an isolator switch as used in motorsport ?, if so, the engine will continue to run if the switch is switched off but the
ignition switch is still in the on possition
who cares who wins
pass the pork pies
ko_racer
posted on 20/3/18 at 09:03 AM |
It all depends how you wire it.
If you use all the original safety circuits and wiring, turning off the power switch will cut the Injectors and ignition which will stop the
engine.
If you use an FIA kill switch and turn it off with that you have the risk of the engine not turning off as there is still power coming from the
generator. The resistor is wired to send this to 0v in this situation, which stops the engine.
number-1
posted on 20/3/18 at 02:47 PM |
Cheers for the replies folks. It makes sense now.
I think i had confused myself with 'learning on the job' that i am doing.
