Simon
posted on 26/2/23 at 12:57 AM |
Steel for van ramp
I want to make a ramp for my van (Vivaro) so I can get my motorcycle and lawnmowers etc in and out. I keep looking on ebay/marketplace and nothing
comes up (that ain't very expensive). Long, foldable and quite wide (so i can walk the bike up it).
It will be foldable and I may bolt to floor of van as a semi permanent fixture.
The bike weighs just over 200kgs and I'm another 120 (on a bad day). Ideally I want it to be about 8' - 10' long. It will be supported
by bracing to the floor at mid/hinge point.
Just wondering what people think might be best size steel to use - I'm thinking 50mm x 25mm but wonder if 25mm x 25mm will be ok? Ought to
clarify, it'll be 2 off box along the length with angle for the "footplates"
Thoughts/alternatives etc welcome please
[Edited on 26/2/23 by Simon]
Mr Whippy
posted on 26/2/23 at 08:57 AM |
these don't look very expensive but everything's relative...
link
gremlin1234
posted on 26/2/23 at 08:58 AM |
the pics in this advert for a wheelchair ramp equiped vivaro may give you some ideas
l8AAOSwnLBj6P2C" target="_blank">https://www.ebay.co.uk/itm/165935490148?hash=item26a286a464:g l8AAOSwnLBj6P2C
motorcycle_mayhem
posted on 26/2/23 at 02:15 PM |
That length, I'd be happier with 50mm by 25mm than the smaller option. Stiffness (and other related attributes) goes up greatly with
cross-section rather than wall thickness. I wouldn't want to wobble with my bikes, not at my age.
I use a long aluminium ladder to which I've bonded (Silkaflex) heavy duty plywood (that stuff with the brown cross-hatch on it, forget the name)
down the rungs. Really does the job. It's long, strong and light.
My Transhit is a (elderly) RWD model, so the rear is quite high. Yours will undoubtedly be far newer, perhaps even FWD, so hopefully not such a
terrifying height. I've never mounted a winch up front to pull the bikes up, but it's an option that is starting to look more appealing as
age and decrepitude take hold of me.
