Author: Subject: Best way to bond a wooden window sill to slate tiles?
posted on 3/3/24 at 03:53 PM Reply With Quote
Advice please?
Looking to fit a wooden window sill to an already slate tiled window sill area. Ideally looking to bond/adhere in some way.
Suggestions for best adhesive?
posted on 3/3/24 at 05:25 PM Reply With Quote
Does it need to be a waterproof seal? I'd use either adhesive foam (expanding foam that doesn't expand) or regular silicone sealant. Either will stick like the proverbial.
posted on 3/3/24 at 05:59 PM Reply With Quote
In a bathroom, so yes, waterproof.
Liking the foam idea.
Any brand recommendations?
posted on 3/3/24 at 06:10 PM Reply With Quote
I use a lot of the plasterboard adhesive foam by soudal, or window frame fixing foam. Both at screwfix. However, I'm not sure the foams are waterproof. You'd have to finish with silicone anyway.
cliftyhanger
posted on 3/3/24 at 06:20 PM Reply With Quote
I wouldn't use a sanitary silicone for bonding to anything vaguely porus. But an LMN silicone is superb as an adhesive and sticks to everything (as long as it isn't wet)
jacko
posted on 3/3/24 at 07:25 PM Reply With Quote
Sikaflex or any pu glues
G
555
rgrs
posted on 7/3/24 at 11:06 AM Reply With Quote
CT1 sticks almost anything to everything
