New Topic New Reply
Author: Subject: NEW Super Light Weight Pedal Box
Optimum Balance Products
posted on 15/1/08 at 08:54 PM Reply With Quote
NEW SUPER LIGHT WEIGHT ALL IN 1 RANGE ONLY 2.3 Kg
Our Signature Easy 2 Fit All In 1, 3 Pedal Floor Mounted Cable or Hydraulic Clutch assemblies have just got better. We have spent 6 months reducing the weight and improving the response and feel of our floor mounted pedal boxes.
The ergonomic design of the pedals, together with low friction oil impregnated bearings gives the Signature All In 1 Range a smooth and responsive feel.
As before the All In 1 range offers great flexibility making it suitable for a wide range of applications. This SUPER LIGHT WEIGHT assembly is designed to provide car builders and race teams with an all-inclusive system that is fully adjustable, simplifies installation and is easy to service. Our pedal box is used with a bias bar system and dual master cylinders, allowing you to have a fully adjustable twin braking system. These floor mounted units have been fitted into all types of cars from race cars, hot rods, kit cars, performance cars, classic cars, etc. It is a very versatile system.
The ergonomic design & efficient action of the assembly provides feedback that inspires driver confidence, helping produce faster lap times.
Obp Ltd SUPER LIGHT WEIGHT floor mounted All in 1 assembly is a value-packed solution to the pedal needs of most car builders.
Pedal Box Dimensions: 230mm Long x 130mm High x 130mm Deep Approx sizes.
5:1 Pedal Ratio.
Check the new SUPER LIGHT WEIGHT RANGE at www.obp.uk.net or use this link :
http://www2.obp.uk.net/catalog/index.php?cPath=32_52_91_102&osCsid=40c867c839d88e89148f8291c8e8c854
Thank you for your time.
Regards
The Obp Team.
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site www.obpltd.com
All the best,
Obp Ltd.
New Topic New Reply
