New Topic New Reply
Author: Subject: NEW SUBARU IMPREZA Pedal System
Optimum Balance Products
posted on 30/7/08 at 03:49 PM Reply With Quote
(This may be of interest to you or you may know some one that this will interest)
SUBARU IMPREZA Hyd Clutch floor mounted cockpit fit hi-efficiency pedal system.
This pedal box will fit all types of SUBARU IMPREZA. Our light weight range dual brake master cylinder bias controlled pedal boxes have been designed to offer the driver the highest level of efficiency in this critical area.
The ergonomic fabricated pedals, together with low friction and high quality oil impregnated spherical bearings set new standards in pedal box design. This unique 6:1 pedal ratio SUBARU IMPREZA floor mounted cockpit fit hi-efficiency pedal system design allows an incredibly easy installation. This system needs no cutting of holes, or modification of any type. The pedal box fits to the floor pan and is designed specifically for the SUBARU IMPREZA floor pan configuration.
The cylinders are mounted under the driver’s feet for optimum space utilisation and access. This is the only floor mounted 6:1 pedal ratio pedal box on the market that is designed specifically for the SUBARU IMPREZA.
This system is perfect for Rally cars, Time Attacks, Track Days or Fast Road cars.
Check it out at: http://www2.obp.uk.net/catalog/index.php?cPath=32_52_160&osCsid=13274a691022605f8482ddb24227697b
Thank you for you time.
Regards
The obp Ltd Team.
[Edited on 27/8/08 by Optimum Balance Products]
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site www.obpltd.com
Thank you for your time.
All the best,
Obp Ltd.
New Topic New Reply
