using 1mm box section
dt21jb - 24/9/10 at 03:59 PM
is 1mm to thin to build the haynes chassis
or should i stick to the 1.6mm
dan
MakeEverything - 24/9/10 at 04:09 PM
1.6mm sounds verry thick. i think i used 1.2mm.
AdamR - 24/9/10 at 04:35 PM
I can't comment on whether 1mm is too thin from a structural point of view (and I hope you do a detailed FEA analysis rather than taking anyone's word for it on here) - but certainly the usual 1.5/1.6mm is easier to weld effectively.
l0rd - 24/9/10 at 04:42 PM
Depends on the usage.
1mm will be too thin i believe.
1.2mm would be ok for track use
1.5/6mm would be ok for road use.
If you haven't been around for long (neither have I) but i have seen a racing chassis of a westfield fail as it was used on the road and i believe the weight reduction was on the chassis tubes thickness.
I am sure, that someone else will come and correct me.
Myke 2463 - 24/9/10 at 04:56 PM
16 swg was the std spec for both Haynes and Locost books.
Strontium Dog - 24/9/10 at 05:03 PM
SWG to mm
http://www.newcircuits.com/article.php?id=tut003
I'd stick to 16 swg for road use. 18 swg if used for a track car should be inspected regularly (very regularly if you like the curbs etc.) !
t.j. - 25/9/10 at 06:48 AM
i'm using 2 mm but next time 1.6 mm
I'm sure if you're a great welder and can cut the parts perfect you could drop to 1.2 mm. But maybe some extra triangles needed.
But is it worth all the hassle?
Grtz
dt21jb - 25/9/10 at 02:08 PM
i'm planning to tig weld my chassis seen as i'm a fab/welder.
my boss who builds his own hot rods,currently i'm building his chassis a 33 roadster reckons 1.6 is better for it.
dan
hughpinder - 27/9/10 at 08:54 AM
16g (1.5 or 1.6 mm) is standard, 18g for 'race' chassis (1.2mm), and as said this will have regular inspection. 1mm may well be strong enough in theory, but for a road car don't forget some corrosion allowance.
Regards
Hugh
Liam - 27/9/10 at 10:41 AM
Most standard chassis, particularly in the engine bay, are far from perfect spaceframe designs and have lots of bending load on some tubes. I wouldn't go thinner than 16SWG unless the design was being improved in these areas.
