Hi Guys,
Home made electric reverse is now in and working! yes its slow, but only weighs 2.5 Kg and takes 10amps max...
Will be up Forrestburn in a couple of weeks.
http://www.youtube.com/watch?v=nylXKCb2Tkc
Welcome stranger
Andy You are wasted in your present job
took this picture this evening in your town
[Edited on 13-6-10 by mangogrooveworkshop]
More elegant than my solution.
Well done mate
ah, thats pretty cool i i like it
Like it alot
Hi Pat how's it going!
going to test it over the next month or two might start making them up for people if there is any interest.
so what sort of motor is that moving the gear wheel then? looks like its the whole motor being lifted into contact then hit the power button - is that how it works? cool idea if it is..
Yes the whole motor/gearbox is moved up to the diff mounted spur gear, its a small motor with a high ratio gearbox of about 100:1 and is much better than using a brutal starter motor. Gears are 10mm alloy. It moves my car back at about 2mph but it will move it over a 1" block of wood no problem
I like that, looks slick, will look nice all finished off, what does cost then mate?
If you fancy making any others i'll be needing one soon.
That likes quite a good system and as most other comments would be interested in one if you do make a few up
Seen it at the weekend. Very elegant. Congrats Andy
Just an update on my electric reverse set up.
I have been using it over the summer with no problems so far. It is slow but will move the car backwards every time. Its been wet and dry several
times now!
I was wondering what the interest would be if I developed this into a kit. The main demand I would think would be from the racing fraternity because
of its light weight. I would have to put some work into some cad drawings etc. and I dont want to do that without some feedback. I would also need a
guinea pig to try installing it in their car. I can take some more pics etc if wanted.
Thanks Andy
what sort of money would you be talking about
cheers
I would Andy but I reckon I'm going to be very much in the minority needing it to act on the prop adapter because I'm Live Axle...
Hi
will this work on a live axle
Got to meet MSA regs next season
John
Well, that's three live axle cars Andy... we'll await your response!
i would guess the race boys would need it a bit faster so the gear ratio on the motor may need altering
Nobody is realistically going to reverse in a race... If your nose is against a barrier you're virtually out of it anyway. 10k rpm and a dumped clutch will get you out of most situations.
I'm interested in a kit as i have a live axle aswell.
