The selector shaft on the MTX75 comes out of the back of the gearbox, IIRC. How would one set up a system whereby one could use the original gearlever
in a mid-engined car?
Would it be feasible to run the cables across the back of the engine, up the right hand side of the car (so right hand gearchange) and use some kind
of reversing bell-cranks to get the motion correct, so that the gearlever is in the conventional orientation?
All advice and opinions welcome
John
I'm planning to use 2 sets of cables - the gear lever ones will go forwards and loop over the drivers legs/steering column and join to the second
set of cables attached to the outer drivers side chassis rail ... but I have't actually done it yet!
This keeps the gear lever set up standard. Obviously I can use a piece of stud or rod of appropriate length to joint the 2 pairs of cables (I
hope).
The gear lever mount plate is about 3.5 inches wide and you would have to do serious mods to fit it on the drivers side. by the time you've
allowed for sidedto side motion. You would probably find it easier to set up some kind of sequential change mechanism since the 2 cables just need
back/mid/fwd motion.
Regards
Hugh
[Edited on 5/5/09 by hughpinder]
I thought you might get more replies on this - might change my design if anything good came up. Perhaps you should re-post in the 'engine and
transmission' section?
Hugh
Not sure if it's the same gearbox, but there is a kit out there that uses the Focus engine/gearbox, they use long cables coming out of the front
of the change, round by the passenger feet & then round the back. Just can't remember it's name sorry, it was at Stoneleigh last
weekend.
Alan...
i had issues with gearshift on my rocket as although my gearbox is cable operated, its not as easy to re route as the IB5. im on Mk2 linkage now and
all i can say is the simpler it is the better!
john,
can you post some pics of the gearbox in position? and maybe a guide as to which direction relates to which gear pair.
Will
Originally posted by dinosaurjuice
john,
Will
I had a similar problem with my mid-engine installation. I've used two bell cranks and two cables. The bell cranks are arranged so that the
cables attach at a low point and run under the engine and gearbox back to the gear lever. I can post pic etc if you wish.
It works really well and is adjustable to get it right
Rob
I don't know if this helps, but what I've been doing with the GM Ecotec FWD package is routing the stock shifter cables underneath the
oilpan near to the flywheel end and up to the rear firewall where the stock cable length terminates. I then use rod extensions up to the shifter assy
which has the bellcrank for throw reversal at that point.
Here's a pic of what Jim did
[Edited on 5/6/09 by sgraber]
Here's a couple of pics of my set up (gearbox end). Bit difficult to photo as most is hidden.
Hope this helps
Rob
Hope this helps
Rob
Hello Guys.
Here's a few pics of my home made gear change system that may help.
I used a Ford Focus gear lever base and had the control cables lengthened (as it happens it would have been cheaper to get a set from Demon Tweaks!!).
I connected it to my now mid-engined Lancia transaxle using its original shaft with one arm doing the sideways motion and t'other up and down as
per pics.
Surprisingly it was very easy to adjust and set up and hasn't needed adjustment in 2 years and 1500 miles. Total cost was £150 (£140 for
cables)
[Edited on 7/5/09 by robroy]
Hope this helps
Rob
Yes, it does. Is that the earlier (rod change) Mondeo gearbox (ie Mark I mondeo)
