Pre Sva pics for discussion
omega 24 v6 - 1/2/09 at 03:54 PM
Well I think I'm done guys and galls. here are the usuall pics for your perusal
Things I know still need doing are
Toe in is way to much so needs setting
Speedo needs checked
Headlight aim to set
Pass side belt top mounts to cover.
The wideband 02 sensor and cabling will be removed pre sva as well.
Anything else your eagle eyes spot.
[img][/img]
speedyxjs - 1/2/09 at 04:16 PM
Nice build
Colour scheme looks good too
Mark G - 1/2/09 at 04:51 PM
Can't really see from the pics but are your reflectors built into the lights in the rear, as I can't see any if not?
piddy - 1/2/09 at 04:58 PM
ditto on the reflectors
omega 24 v6 - 1/2/09 at 05:02 PM
Yep in the outside light the ring round the outside. Pics are a bit sh*t cause there from my phone as my camera batteries went flat.
DaveFJ - 1/2/09 at 05:22 PM
looking good.
is the fog light lens vertical?
good luck with the test.....
omega 24 v6 - 1/2/09 at 05:25 PM
Yes it's adjustable ( for now )
caber - 1/2/09 at 05:33 PM
the angle on your transmission tunnel has to meet 3mm radius rule. I failed on standard ally angle on my build, I had to replace it with radiused angle. The rest looks fine to me.
Caber
omega 24 v6 - 1/2/09 at 05:35 PM
The angle is table edge or J section as they call it so should be OK I hope.
jacko - 1/2/09 at 06:46 PM
Front indicators look a bit short
omega 24 v6 - 1/2/09 at 07:05 PM
They do in the pic and are really close to the limit ( but within) in real life. They also JUST clear the wheels on full lock.
Shamrock GS - 1/2/09 at 08:50 PM
Nice looking car - good luck with the test
Gary
