Just a quick one...
I've got standard 240mm vented disks and Girling calipers on the front of the VortX at the moment. I've bought some Powerlites and want to
change over to solid disks, keep the same PCD and mount up the Powerlites.
Question is, can I just buy standard sierra solid disks (diameter? 240mm? or are there bigger?) and just make up my own adapters? Or can you buy the
adapters separately?
Thanks,
Chris.
[Edited on 1-8-11 by Winston Todge]
If you use the wilwood adapters you'll need the wilwood discs. They are different to sierra ones.
You could make your own spacers to suit the sierra discs, but not sure if the wilwood pads would line up correctly.
Rally Design will sell you the wilwood adapters and discs, if not you they will to me and I'll send them on.
The wilwood disc is 257mm btw and will go under 13s with same pcd and offset etc.
[Edited on 1/8/11 by Ben_Copeland]
I bought the powerlite kit from rally design to replace my vented disk setup, bolted straight up and works lovely
