Is it possible to use a rose joint instead of a top ball joint? will it give enough vertical movement?
This is what i need to make and a rose joint would be easier
Formula 2 stock cars use rose joints top and bottom
They are available from McGill Motorsports Thats where i borrowed the picture from
Give him a call he should be able to help you out. (His number is on his site)
Ronnie
cheers ronnie that helps alot
If you are looking to use your car on the road then you might want to be careful about using rose joints. They don't have the longevity of a ball joint.
