I am running a twin master cylinder with bias bar set up.
Does the switch want to go in the back line or front for the best operating presure ?
Having done a search some say back others say front.
cheers
Yep front
In the back as it fitted in with the rest of the wiring.
Hi mate
Just my personal opinion but i would have to say in the front line due to the higher pressure but that's not from experience so we will have to
see what others say.
Front as it's a bias box. Basically there will always be more pressure in the front line. If you put it in the rear line then under very light braking it may not even come on depending on what pressure it's set at. I'm sure someone on her had problems with it in the rear before
I have bias twin cylinder and its in the front
Front. And you can use a banjo bolt switch which makes
the installation really nice!
Wyn
To be 100% legal it should be the front --- largely forgotten part of the old road traffic acts.
Hi.
As Wyn has ^^^ said the banjo bolt switches are very good. As for the other more common type if you use one from the range of older MG's etc they
will work fine in both the front and also in the rear of the rear brake line they work with light pressure. Also there is a 4 way T piece from that
range of cars which makes mounting the switch easier than breaking into a line elsewhere. ( Is it possible to have a 4 way T piece. You know what i
mean )
Unlike some of the racers who fit the ones that need very high pressure to work but can be made to work to pass a scrutineer by standing on the brake
pedal. Mind you they tend to change them when other drivers keep running up the back off them .
Cheers Matt
anyone got a pic of banjo bolt in use?
Ive fitted t piece type switch in rear line and it doesnt work well. Probs better in front. Ive since learnt that there are different pressure switches available. Apparently series 2 land rovers use the lower pressure switch (only know about land rovers as my mate repairs them).
Hi
Slightly off topic but is it no longer permissable to have a microswitch activated by the motion of the brake pedal?
Regards Mick
Banjo fitting - here - scroll down to SAE Brake Adapter banjo
fittings and Metric Brake Adapter banjo fittings
Wyn
cheers all
Originally posted by Mix
Hi
Regards Mick
