As title i purchased this diff as a spare and have never fitted it ,when i got the diff it had 3.9 ratio crown wheel and pinion but the pinion was
showing signs of cracking due to bad set up
I have stripped the diff and replaced the crown wheel and pinion with good second hand crownwheel and pinion also i have fitted a new crush spacer and
diff oil seal All bearings are good timken items
This diff has a large flange but i do have a small flange available if required
IMPORTANT BIT
this diff has been rebuilt but not fully tightened ie it will need the preload to be set up properly hence cheap price
£325 plus delivery
what axle is it for?
i didn't think atb diffs has a preload setting?
ban1216
Sounds like an English one - if it can I have first dibs please!
Wyn
It is an english one and does need the preload setting for the crown wheel and pinion and also the spacer needs to be set up and crushed to the
correct poundage and i am led to believe the 2 bearing carriers need setting to the correct distance apart
I think you may be mistaking preload with ramp angles on plate type diff
Any way
SORRY SOLD FIRST THING THIS MORNING SORRY
have to be quick to get a bargin
FORSALE AGAIN due to lack of funds
lsdweb gets first refusal
If lsdweb doesn't want it I will definitely take it, cash waiting
awww999 you got second dibs
where are you based ??
I'm near jnc 10 of the A1 (an hour north of London) but I travel about a fair bit for work. Whereabouts are you based?
I am in warrington cheshire
Is it still available? I didn't have this topic on my subscribed list - sorry!
Wyn
