Bike carbs and ignition ecu for zetec
Strontium Dog - 15/5/12 at 11:42 AM
Hi, I have a set of bike carbs complete with trumpets and a GEMS ignition ecu for sale. The bike carbs could be separated and re-spaced if needed and the ecu is 3D mapable. The ecu has a map for a zetec running webbers at the moment but would be a good starting point for the bike carbs on a zetec. There is a loom included to connect it up to your engine but you will need to make a manifold for the carbs. I have a disk with the software for the ecu and the manual.
ECU and software are GEMS Mini Ignition Control System MINIDLS. V1.17 & MINIIGN
I would like £150 for the lot delivered.
Cheers Si.
FASTdan - 15/5/12 at 01:26 PM
Any idea what the carbs are off?
Strontium Dog - 15/5/12 at 01:34 PM
Argh, I knew someone would ask that just because I've forgotten. I do remember that they are from a 600cc bike, possibly a cbr but just not sure. They are made by Keihn (as many are) and are 37 or 38mm across the engine side and about 38mm across the trumpet measured internally using a tape measure as I don't have my verniers to hand. They have square sliders and are cvh type. (they have CVR cast on the bodies).
If anyone can identify them from the pic then please do!
Strontium Dog - 17/5/12 at 09:44 AM
Bump!
Strontium Dog - 28/5/12 at 04:29 PM
OK I really could do with these gone so £130 delivered
nogger827 - 29/5/12 at 11:28 PM
would you consider splitting them im intrested in the ignition system
Strontium Dog - 31/5/12 at 09:24 AM
SOLD
