How much on average does it cost to build one of these system....
a rough breakdown is really what i am after.
What do you want to control with it, just fuel, or spark or whatever?
it will just be the the Fueling
Megasquirt II extra, with loom - £300
Sensors - £50
Throttle bodies - £100
Fuel system (pipe, hose, fuel pump, swirl pot) - £150
Fuel rail - £50
So I would budget on around £700.
If you want to self tune correctly, then a Wide band controller is a big help - £200
[Edited on 27/11/08 by Jenko]
For just fueling a MS1 would be sufficient, which is cheaper.
What type of engine / no. cylinders.
As above, fuel and sparks?
Thottle bodies or not.
Ugradge to current ECU or carb. replacement.
My Suzuki Carb. conversion to ITB's was on a budget.
Megasquirt V2.2 kit from the USA cost less than £100 but then over $1.80 to the £1.00
Glen's Garage link
Don't for get import duties/VAT.
I built mine (goes with my job)
You can either DIY, get a mate to do it for mates rates or get one ready built.
like Here
Note, you will need good soldering / build quality or risk brake downs.
Suzuki GSXR600 K1 thottle bodies + injectors £30 but often well over £50
(ebay)
Fuel rail blank £20
Suzuki GSX1400 fuel pump/regulator.
Argon (halfrauds) x 2 (£15.00) for stainless fuel pump / swirl pot tank.
(ebay)
JAW wideband controller / display £50
JAW link
Bosch W/B sensor £60
grahamgoode
There are some photos on my web pages (bit naff though)
Martin
