hi anybody out there got a mbe 956 map for a c20xe running cream injectors and gsxr throttle boddies i can have a copy of
hi are you running a coil pack or dizzy
i might have something close
yep but its a last resort as you'll have to plug into my laptop, as the usb doesn't work and nor does the disc drive!
hang on, isn't it you who already had the map off me donny?
im running an external coil pack
hi nat yes its me im useing loads of fuel with the your map and it keeps backfireing when cold and i think its becauce your useing jenvey t/b and im useing gsxr t/b im trying to get a map from someone who is running gsxr t/b to see if it is the map or something wrong with my ecu as still cant get temp setting down
