Just bought one of these to try and play around with the mixture on my N16 pulsar motor and I'm just wondering if anyone here has had any experience with them.
It's rather too simple to be safe or effective if I'm reading the description correctly.
If the only thing it is doing is mapping the AFM output voltage to a different level, then how does it differentiate between low engine speed, wide
open throttle and higher engine speed with a partialy open throttle where the air flow could be the same?
I see no reason why it can't be safe or effective (though there's a big scope for getting things wrong)...
as a step between sticking with an ECU and going for an aftermarket ECU it looks like a nice bit of kit (especially as it can be removed simply if you
ever sell the car).
though personally I'd go for a fully mapable ECU and take full control over the engine.... the interceptor will make the ECU change fuelling and
ignition- it won't be possible to change one and not the other.
Its the kit sold by jaycar, if fitting I would advise making up proper breakout connectors.
My understanding of most hot wire AFM systems (mainly based on the Lucas with the Hitachi hotwire as used on late 1980s Rovers) the the hotwire
output was only used at lower end of the speed range.
With age the hot wire AFM go out of calibration by a mile -- the voltage of the output signal drifts slowly upwards so it could be useful device.
Originally posted by britishtrident
My understanding of most hot wire AFM systems (mainly based on the Lucas with the Hitachi hotwire as used on late 1980s Rovers) the the hotwire output was only used at lower end of the speed range.
