im just reading through the MS manual again and it says
Connect your laptop to your MegaSquirt using a DB-9 cable, turn the ignition to run (do not start it), and verify that all the sensors give reasonable values. The MAP should be about 100 kPa, the coolant and intake air temperatures should be approximately the same as the outside air, and the TPS should read from 0 to 100% as you open the throttle.
P Atmos
MAP = manifold absolute pressure
100kPa is about 1Bar so... yes.
adrian
adrian
so am i correct in saying that the faster you go the lower the kpa reading should get? im a little confused.
if you're using speed-density rather than alph-n, you'll find an ideal MAP - as you tune the engine the MAP will go lower and lower - then
you'll get to a point where whatever you do (fuel up / down, spark earlier / later), the MAP will go up again...
Did you get the msq last nite btw?
I got myself a headache the first time I had to think this through for Megajolt...
Engine stopped - MAP will be around 100kPa (atmospheric). Engine not sucking in air.
Engine ticking over, foot off throttle - MAP will be very low at around 20kPa (high vacuum). The engine will be trying to draw air in past the closed
butterflies.
Engine running fast, foot hard down - MAP will be approaching 100kPa (near atmospheric). The engine will be sucking in air, but the butterflies will
be open so very little restriction and no chance to build up a vacuum.
CHEERS GARAFE MAN, that makes it easy to understand.
