i have high impedence injectors on my ITB's, the ms manual says
To tune the PWM [pulse width modulation] values for your engine, you need to know what kind of injectors you have: low impedance or high impedance.To tune the PWM [pulse width modulation] values for your engine, you need to know what kind of injectors you have: low impedance or high impedance.
If you are running high-impedance injectors (greater than 10 Ohms), then set the:
PWM Time Threshold to 25.4 msec, and the
PWM Current Limit (%) to 100%.
In essence you are disabling the PWM mode. This allows full voltage to the injectors throughout the pulse widths.
Yeh, there's something different you have to do with the low-impedence ones, but if you have high-impedence you can just bung in the settings
from the manual and forget about it....
Vince
If you use car injectors these will tend to be 10ohm each, bikes are around 50ohm.
The output transistors on the MS standard board can run a pair of bike injectors without boiling up so a 25ohm load as parallel wired.
A pair of car injectors would be a 5ohm load which causes problems, MS deals with this by giving pulsing the current to the injector, so a long pulse
to open it then lots of little pulse to hold it open, this effectively halves or quarters the load on the transistors, pretty clever really.
regards Mark
