I've been having a nightmare of a time trying to get my V6 fueled right - no matter what I try , it will not run lean at tickover
I was just having another go at it , and I just noticed in `realtime display` that accell enrichment keeps cutting in - while it's ticking over
at 800 RPM - putting the AFR down to around 10 (from a healthy 14) every 2 seconds .
WTF is going on
Either needs dampening on the MAP line or you have noise on the TPS depending on what you are using for AE.
Or your threshholds are set too sensitive.
http://www.msextra.com/manuals/MS_Extra_Tuning_Manual.htm#rpmae
looks like the rpm settings are adjustable
have you read the manual?
Accel Enrichments page
have you read the manual?![]()
you got it set upi then, i have been reading about autotune and ego corrections today, even went out for a little spin.
