Thinking of setting this up in my bike throttle bod conversion. has anyone done this with 2 sets of injectors (standard zetec fuel rail and bike set
up) on megasuirt. if so is it easy to set up, and how are the 2nd set of injectors connected on the ecu ?
struggling to find wiring/set up info on MSquirt site. thanks
Megasquirt only has 2 banks of injectors. You would have to use one bank for the head injectors and one bank for the throat injectors.
Unless you have a very small set of head injectors (unlikely if they are standard Zetec ones), you will suffer from poor tunability at idle and low
throttle openings.
Hi Ben,
who made that airbox for your ecotech? Im after something similar for my XE, the pipercross ram air is very expensive!
Originally posted by BenTyreman
Unless you have a very small set of head injectors (unlikely if they are standard Zetec ones), you will suffer from poor tunability at idle and low throttle openings.
I looked into this for my duratec and rapidly decided it was too complicated and just bought some bigger injectors to fit into the head from the
states and will blank off the throttle body holes. A complete set worked out at around £100.
I've been wondering about this for a while - using the normal injectors for low throttle / around town driving , and and then for higher speed
stuff having a second set mounted up stream of the butterflies (F1 style...)
Something like this.....
[img][/img]
Originally posted by cd.thomson
Hi Ben,
Originally posted by MkIndy7
You can have megasquirt running on the standard head injectors (which are already appropriately sized) at low rev's, vacume or TPS and then switch over to the TB injectors or run them as well at the higher switch point you chose.
As said there's only 2 injector drivers on MS so you have to have them firing simultaneously.
Unless they've updated it don't use the swiching over calculations for the fuel from the Megasquirt manual they are wrong, use the values from the Megatunix software or manual, can't remember wich.
